2007-06-20
09:53 PM
2025-07-16
10:51 AM
Aruzhan Ilaikova
2007-06-21 12:21 AM
2007-06-21 04:24 PM
2007-06-21 09:54 PM
2007-06-21 10:29 PM
2007-06-22 01:16 AM
JDC001 wrote:We need a Screen Shot.
A couple of problems...
1. The attached screen shot shows how two windows inserted in walls affect the adjacent walls immediately beside the window. One has a whited out area next to the window and the other has changed the insulation pattern to blue and has extended the interior surface into the wall at the 90 degree point.
JDC001 wrote:I usually place the "second" window using the middle snap point on the "first" window. As far as the Marker, I just check the "Flip Marker" box under the Marker Settings. For window types that are usually placed above other windows I have a Favorite set. These Favorites have the correct type aprons set for my "high" windows and the marker is set to be Flipped as default.
2. Is there an easy way to insert one window on top of another in a wall section and if so, how do you put a window marker on each so that it shows up in the floor plan?
JDC001 wrote:Chris already stated were you need to look for this. I can not say that I completely understand the differences. With Composite walls and Exterior Trim over Siding I have found the Solid Wall type to display the most accurate.
3. I have created a new composite wall with 1/2" plywood/5 1/2" foam and 1/2" plywood. When a window is inserted in this wall, it sets the frame at the face of the foam, rather than at the face of the plywood, which is the outside face of the wall. Is there a setting to get it to move the window out? See Screen shot
Thanks,
Jay
2007-06-22 01:58 AM
Sam wrote:Thanks - I have to say, I'm completly confused - there's the AC doors and windows, the cadimage tool, and this library (and more, I'm sure) I'm trying to figure out what's best for me so that I don't spend lots of time configuring one type only to start all over again because I discover a hidden limitation and have to switch to something else. Any suggestions or pros/cons anyone?
I use real windows and doors from 3d smartparts
http://ddgi.com/object_shop/d3sp-dl02.html
2007-06-22 06:30 PM
2007-06-24 02:23 PM
Chris wrote:I use door and window builder and the door elevations were not showing up in my interactive schedule in the 11 release. They have since corrected this problem. One other issue I have had relating to schedules is that in the latter releases of door and window builder they have hidden the listing parameters which are common to standard archcicad windows and doors. I have had to go into the D&WB library parts and make some adjustments so these parameters show in my parameter list. They would show in my schedule, but I was limited to only adjusting these in the scheduling environment versus in the window or door dialog box. I have included a screen shot showing where the display for these can be turned on in the library editing environment for any current users who are interested. One other issue I have with scheduling is that the garage doors with D&WB do not have these parameters included with the part so I use standard garage doors. Otherwise I can mix and match D&WB door and windows with standard archicad doors and windows and use the interactive schedule without incidence.
Also, I saw elsewhere that using non-AC doors and windows can cause problem creating schedules? Is that the case?
Thanks!!!
2007-06-24 08:00 PM
