Zone Stamp angle
JGoode
Hello,
Is there any way to access the zone stamp angle that is set in the zone settings from GDL? even if you can only read it.
ArchiCAD 27
Windows 10
5 REPLIES 5
Nope... I added another parameter to drive that using hotspot in my stamps ;(
Piotr
SYMB_ROTANGLE works for me.
not exactly - it cannot be modified via hotspot (or via parameter command) for example...but yes it is the parameter that is in the infoBox.
Piotr
No you can't modify it by a hotspot - but then you can't do that for any object.
But you can add your own rotation parameter and hotspot that.
ROT2 -SYMB_ROTANGLE first will undo rotation the user inputs in the info box if that is important.
I was refering (maybe I was wrong) _only_ to the ability to use that parameter for hotspots and so on...
Anyway all those parameters should work normally (hotspots and so on)
Piotr
