‎2015-11-18 12:44 AM
‎2015-11-18 01:16 AM
‎2015-11-18 06:33 PM
Barry wrote:
As far as I can see by looking at the list this 'zone_relations' request is not affected.
http://gdl.graphisoft.com/gdl-docs/changes-in-ac19/
‎2015-11-25 05:37 PM
‎2015-11-26 02:44 AM
‎2015-11-26 03:39 PM
Barry wrote:
Check that the view you placed as a drawing on your layout has the same layer combination, Model View Option and Renovation Filters as your floor plan.
The easiest way is to select the drawing in the layout, right mouse click and choose 'Open Source View'.
It should open with exactly the same settings as the what you see in the layout - i.e. the zone names should be missing.
That means you need to make changes to the layer combination, MVO or Reno filter and update the view settings.
