Scott Bulmer
Zone stamp that shows actual area and area load increase
Greetings,
I need a zone stamp which returns area values in two ways: the actual area of the office suite as well as an area field based on multiplying the actual area by the common area loading factor for an office. This is to satisfy BOMA leasing standards for office buildings. The common area loading factor would be manually input, and the two area values would be visible in the zone stamp. I am currently adding a text block below the zone stamp with this info, however it would be nice to have the content contained within the stamp.
Thank you for any guidance.
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Hi Scott,
I recently created a zone stamp for another ArchiCAD-Talk member. If you like I can give you a modified version that includes your area calculation. Let me know what other information you want to display, and in what format.
If you like you can contact me direct at [email protected].
