jd10003
Change Marker Object Rotation
Is it possible to rotate the label for the change marker object?  I'm attaching a screenshot of the marker as it appears on my sheet and the info box.  It shows the way I want it in the info box preview, but the actual label on the sheet doesn't match the rotation shown in the preview.  No matter what I change in the object controls, it remains vertical on the page.  I can rotate the text within the triangle, but I can't rotate the entire thing, even though the preview shows it the way I want it.
What am I missing?
1 Solution
Lingwisyer
Guru
That marker object is scripted to be a fixed angle. Unfortunately you cannot just simply remove the initial rotation in the script as that will move the cloud as well as disconnect the marker from the leader...
Ling.
Go to post
Lingwisyer
Guru
Ling.
