2026-04-13
07:03 PM
2026-04-16
03:33 AM
Is it possible to rotate the label for the change marker object? I'm attaching a screenshot of the marker as it appears on my sheet and the info box. It shows the way I want it in the info box preview, but the actual label on the sheet doesn't match the rotation shown in the preview. No matter what I change in the object controls, it remains vertical on the page. I can rotate the text within the triangle, but I can't rotate the entire thing, even though the preview shows it the way I want it.
What am I missing?
Solved! Go to Solution.
2026-04-14 04:20 AM
That marker object is scripted to be a fixed angle. Unfortunately you cannot just simply remove the initial rotation in the script as that will move the cloud as well as disconnect the marker from the leader...
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2026-04-14 04:20 AM
Ling.
