background filling on 2d full view of a window or door
How do I put a background color on a 2d view of a window or door. When I make a simple code with lines it looks transparent on plan. If I use a fill at the GDL, it makes the side lines of the window look too thin.
Thanks.
4 REPLIES 4
Try narrowing the fill polygon so that the wall contour line shows
it's true thickness.
Peter Devlin
What's is your code in GDL to do the background? Can't I send the Background fill under the wall lines? How do I do it?
Thanks
Parameters:
frw is frame width
jd is frame depth
itrd is interior trim depth
etrd is exterior trim depth
A is nominal door width and the opening
must be drawn to outside of frame.
Hence opening width is A+2*frw
fill "Empty Fill"
poly2 4,6,
-a/2-frw,-jd-itrd,
a/2+frw,-jd-itrd,
a/2+frw,etrd,
-a/2-frw,etrd
Peter Devlin
Thanks a Lot. I'll try it.
