bench
abdelaziz
please, help me to get this parametric object
AMD Ryzen 5950x
AMD RX 9070xt
AC28
7 REPLIES 7
Hi
We will gladly assist you with this object, you can get a hold of us through www.bimbakery.co as we have a couple of questions regarding the calculations and desired output
Regards
Wesley
Hi
Here is a video for the object we put together for you, download link is in the description of the video.
https://youtu.be/qLR2WjX02HI
Regards
Wesley
abdelaziz
yes but the height of the steps must vary according to it and fixed C
the formula must be repeated for each step
AMD Ryzen 5950x
AMD RX 9070xt
AC28
Hi abdelaziz
We have adjusted the object so you can either calculate by a fixed C-Value (Riser heights will be calculated) or by a fixed riser height (C-Values will be calculated), you can download the new version from our site.
Regards
Wesley
abdelaziz
thank you very much excellent work "is BimBakery efficiency" I hope that the subject will become more important and shoed your reference whose BIM
AMD Ryzen 5950x
AMD RX 9070xt
AC28
abdelaziz
if possible set a "C" data and sets the depth of the step
AMD Ryzen 5950x
AMD RX 9070xt
AC28
abdelaziz
Sorry Object is perfect
AMD Ryzen 5950x
AMD RX 9070xt
AC28
