chain size
Hi!
I've been using some of the "ready-made" furnishings for my design. Firstly I had no problems with changing the sizes of the objects as I wished, but now there has appeared CHAIN SIZE, which blocks me from changing just one of the measurements ( if I change the length, the width changes as well!) in the object.
How can I get rid of this "tool"?
Thanks a lot in advance!
David Maudlin
Miss Finland:
Make sure the "Chain" button next to the length & width dimensions is not depressed (if it is, then it has lines from the chain to the dimensions). If this doe not solve your problem, you should post the name of the object(s) and/or a screen shot of what you are seeing.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David:
I took a walk and the problem had disappeared in the mean while...
I was trying to adjuste a commercial bath stall, from plumbing fixtures.
Everything seems to be working now...
Many thanks anyways David!
Tiina-Liisa
