controlling text rotation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-01-25 05:00 PM
2006-01-25
05:00 PM
1. Change the rotation of the text so it reads from the bottom of the page when the object rotation is >0. I assume I can use ><= with a range if numbers in an IF/THEN, arrangement to add some rotation adjustment around the anchor point, but if anyone knows a better way, please let me know.
2. How to properly make use of the stw string function. My txt_adj isn't coming up with the proper amount - see the attached screenshot. Per the code:
Define Style txt "Arial", txt_sz, 5, 0
txt_adj=.5*STW(mkr_ID)/1000*A_
Pen txt_pen
ADD2 0, 12"+txt_adj !!!!12" moves the origin to the outside of the receptacle
Style txt
rot2 90
Text2 0, 0, mkr_id
Shouldn't 1/2 the stw put the origin of the text in the proper spot so that when the text is entered, the edge of the text reaches back to the 12" mark? It appears to be starting the text left justified as is I was using 4 instead of 5 for my anchor point.
If this email isn't clear, I'll try to explain further, but I hope its obvious what I'd like to accomplish. Any help would be appreciated!
Wes
10 REPLIES 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-01-26 05:00 PM
2006-01-26
05:00 PM
sure - why not...
!!!!!!!!!!!!!!!!!!!!!!Draw 2D symbol HOTSPOT2 0, 0 HOTSPOT2 0, 5.5" HOTSPOT2 0, 11" PEN pencolor LINE2 1", 0, 1", 11" LINE2 -1", 0, -1", 11" CIRCLE2 0, 5.5", 4" PEN 2 LINE2 4", 0, -4", 0 !!!!!!!!!!!!!!!!!!!!!!!Text ID txt_sz = txt_sz*0.3528 Define Style txt "Arial", txt_sz, 5, 0 Request("ID_of_Main", "", mkr_ID) Style txt txt_adj=.5*STW(mkr_ID)/1000*A_ Pen txt_pen !!!!!!!!!!!!!!!!!!!!account for mirrored object IF V~ = 1 THEN mir_adj = 180 ELSE mir_adj = 0 ENDIF !!!!!!!!!!!!!!!!!!!control text rotation IF W~ <= 224 THEN rot_adj=180+mir_adj IF W~ > 224 THEN rot_adj=0+mir_adj IF W~ < 30 THEN rot_adj=0+mir_adj !!!!!!!!!!!!!!!!!!!set default location ADD2 0, 12"+txt_adj rot2 90+rot_adj HOTSPOT2 txtA, 0, 4, txtB, 1+128 HOTSPOT2 txtA, -1, 5, txtB, 3 HOTSPOT2 txtA, txtB, 6, txtB, 2 HOTSPOT2 0, txtB, 7, txtA, 1+128 HOTSPOT2 -1, txtB, 8, txtA, 3 HOTSPOT2 txtA, txtB, 9, txtA, 2 !for use only if hotspot is disabled !txtA=0 !txtB=0 Text2 txtA, txtB, mkr_id
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
