owen
copy Parameters
Is there any way to copy individual Parameters or the entire list? (not talking about the Parameters Script)
or
Is there any way of saving a Library Part as a v7 compatible one (if there are no new GDL commands incompatible with 7 in it)?
Here's my problem:
An old project (v7) has reopened and it uses an office custom window part. At some stage since this project was put on hold this v7 library part has been opened in 8 and saved ... so now none of our old projects will read it! I've looked through the script and there is nothing actually new in it which would make it incompatible with 7. I've not yet managed to find a backup of the part before the v8 save was made (back to Oct 2003 so far and still going), so may need to rebuild it as v7 by copy-pasting the bits of the script into a new part made in 7 then saving over it .... fairly quick BUT there are A LOT of Parameters, which are the most annoyingly slow things to modify (get them sorted, etc). This is going to be a slow and tedious process and susceptible to errors when re-entering all of the Parameters so if anyone has any suggestions they'd be GREATLY appreciated.
cheers
owen
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
3 Replies 3
Red
owen wrote:
Is there any way to copy individual Parameters.....
I've often wondered the same thing. I hope there is away because said you said that can be very annoying!!
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
Vitruvius
This won't help with the problem at hand but will help prevent a recurrance.
We name all our custom symbols according to the AC package currently used - for example A-NAME_70.gsm denotes a symbol of AC Version 7. When upgrading to Version 8, we saved the customized v7 symbols and duplicate the symbol names to A-NAME_81.gsm before upgrading to the new version. These can then be customized to utilize the newer features of the upgrade without fear of killing legacy projects.
As most offices only have a few dozen customized symbols, it doesn't take very long to rename.
Cameron Hestler, Architect
Archicad 28 / Mac Studio M4 Max - 64 GB / LG27 Monitors / 26.6 Tahoe
- been using Archicad since V4.55
There are also file renaming utilities that can help with this, if there are a lot of them to do.
