corner widow
hi
i attempting to script a window that around a cnr
i have listed a series of window sizes in 'A' variable and wish to add the wall thickness to the 'A' variable
the 3D scrip is not proving to be a problem as I an adding the WALL_THICHNESS to the 'A' variable
i plan however i do not seem to be able to increase the wall hole size which keeps defaulting to 'A' variable
"A" is a reserved parameter for the width of the window. Use something else.
