downloading from object_depository
hi!I'm new here and i have a problem.i downloaded some objects from object depository and i have no idea how i can upload them to my library..they are all gsm files and i don't know how i can use them as 3d objects in my plans.. i also wanted to ask if it is possible to change their materials or their size and how.. i hope somebody will help me! thanks a lot!
3 Replies 3
Frank Beister
Welcome mediam.
Your question is not new and many answers to this have been posted here. Take you the time to navigate a bit by SEARCHing this forum by the search items "library", "library manager", "adding libraries". Have also a look into the normal ArchiCAD manual and search for this keys. If this does not help, ask again.
... und im Übrigen bin ich der Meinung, dass Trockenbauwände einschichtig zu modellieren sind.
Basically you want to create a folder for your downloaded objects and load this folder with your other Libraries. Categorise folders as applicable so you don't have to load everything to get just the objects you want.
thanks a lot for your help!
