elevator stories
so sorry if this has been discussed, i have looked but haven't found this particular issue. i am trying to put an elevator in my project that has a promenade level at 0-0, a first floor at 3-4, and the other floors following on up at 14-0 and 12-8 intervals. when i put the elevator object in it lines up with every level which is good, but since i don't want the doors to be on the first floor, 3-4, i turn them off but the shaft wall cuts the doors that i do want on the promenade level, 0-0, in half. is the only way to correct this is to do a separate elevator for every floor? i don't want to just turn off the wall as i want the doors and their frames to be visible.
0 Replies 0
