finding missing library parts in the project . . .
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2004-04-22
11:58 AM
2023-05-24
12:14 PM
Rubia Torres
2004-04-22
11:58 AM
it's no longer in our libraries, so pops up as a missing library part each time the libraries are loaded. i have been through
does anybody have any tricks up their sleeve for finding something like this? are patches treated differently to normal objects? any help would be greatly appreciated.
thanks
~/archiben
b e n f r o s t
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-22 03:52 PM
2004-04-22
03:52 PM
I assume you are using Find and Select?
You could make a dummy patch of that name containing a BBB (big black blob) or anything that makes it big and obvious and easy to delete.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-22 07:00 PM
2004-04-22
07:00 PM
Matthew wrote:... and make sure to zoom to fit ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-22 09:38 PM
2004-04-22
09:38 PM
thanks guys.
yes to both: 'find and select' and zoom-to-fit. i've even zoomed into all the areas that i thought might contain it (think it's a slab bearing on ground beams . . .) and doing big sweeping drag selects to see if i could pick up the corners.
haven't tried the big-black-blob method, but that could be a go . . .
thanks
~/archiben
thanks
~/archiben
b e n f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-23 09:51 AM
2004-04-23
09:51 AM
~/archiben wrote:Also, did you open all the sections and elevations? Maybe a section had been removed?
Djordje
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2004-04-23 12:53 PM
2004-04-23
12:53 PM
well. the 'big-black-blob' method worked. thanks matthew. slab on ground patch is no more.
can't understand why it wouldn't show when searching for all elements types by name in find and select. i can only think that there is something about the patch attributes that prevented it from showing in the list of available 'named' elements . . .
good riddance!
~/archiben
good riddance!
~/archiben
b e n f r o s t
