getting "Fill Not Found" message in 3D window
I am getting this "Fill not found" message in my 3D window every time I try to use my AC 10 windows, doors, etc:
"Fill not found at line 251 in the 3D script of file
wa_trim_us_10.gsm."
I've successfully downloaded the new v10 object library and think I have isolated my problem: this problem is resulting from opening my client's .dwg files into ArchiCAD 10 (btw: I had the same problem with AC 9).
When I create a "new and reset" file alone, the windows and doors are added with no "Fill not found" windows showing up when I open the 3D window.
However, when I import my client's .dwg files and attempt to 3D model/trace from them, then I get the "Fill not found" window every time I use my AC Library 10 windows or doors, etc. Obviously, I can't work without my client's .dwgs, so can anyone instruct me as to how to fix this problem?
thanks!
1 REPLY 1
David Maudlin
Grenderer:
Check this topic:
Library Parts Not Working Properly
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
