glass processing machine model needed
ali
I could not find any models of glass processing machines online is there anywhere I can find those
Operating system used: Mac Apple Silicon 14.5 Sonoma
1 REPLY 1
Marc H
Might try going to a manufacturer site and downloading a GSM.  If not available, often they have an Revit (RFA) or other 3d object.  You would then import using the appropriate AC object importer (File > Libraries and Objects > ....
They will often come in with a large size, but helpful until you can create your own GDL object.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
