glob_ui_button
what am i doing wrong?
ii'mtrying to make this button change a parameter called "alu".
the button Works, but the parameter wont change????
6 Replies 6
Hello,
You should have the parameter command
in the master or value script, not in the interface script.
Transfer everything in the master script and leave only lines
ui_dialog.....
ui_pict_button....
In addition I suggest adding an endif
if glob_ui_button_id=1 then
    alu= 1
    parameters alu= 1
endif
Hope this helps/works.
Thank you very mutch MR.Vesen.
Now with your help, it works fine.
Once again thank you.
What about if i want the same button to turn it off?
try a boolean variable in the interface script and an if..then..else.. in the master.
Hello,
This might work (not tested);
    alu= not(alu)
    parameters alu= alu
endif
This should work;
    if alu= 1 then
        alu= 0
    else
        alu= 1
    endif
    parameters alu= alu
endif
Juha solution: smarter and shorter. Good point, thanks
