help meeeeeeeeeee :)
i am student of architecture... i have downloaded some models from archibase, but i dont know how to use them!
please explain me step by step what should i do when i open winzip file...
Provided the models are saved as a .gsm file you can just put them in a folder you can find from ArchiCAD, open the program and load the parts from the 'File/Libraries and Objects/Library Manager' dialogue. Locate the model parts in the left hand window and add them to the project Library parts in the right hand window.
Once you have them loaded into your project just use the Object Tool to place the object where you want it. Hope this is clear.
Gerald Hoffman
ā€œThe simplification of anything is always sensationalā€ GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
thank you, thank you, thank you
