how to save library object made by archicad 15 to AC14 ?
hello i made objects using archicad 15 and saved it as gsm when i open project in archicad 14 trying to take this objects into my project through library manager that did not load the objects made there so what is the solution please help because somehow i need to work on archicad 14
please help for solution
thanks
David Maudlin
ahmed_hassan:
Use the Library Manager to put the objects in an Embedded Library, Save As... that .pln file with the Embedded Library as an ArchiCAD 14 project file, open that file in ArchiCAD 14, then use the Library Manager to Export the library parts. The parts will then be AC 14 format, but any commands new to AC 15 will not translate to AC 14.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
i exported it from archicad 15 to external file as gsm and then when i need the library i call it throught choosing entire folder and it being putted in its own folder not embedded library how i can make my gsm files inside embedded library instead of independent file library noting that any way i am using library manager to call the objects gsm
David Maudlin
For more information with images, go to Help > ArchiCAD Help, when your browser opens click on the "Search" tab, and input "Embedded Library" in the search box, in the results list "Add Objects to Embedded Library" will lead to detailed information.
