how to set surface color for inserted library object
I save a library object from a morph, then inset this type of object , bit the surface material not the same, don't know how to set it.
Please advice, Thanks
David Maudlin
emailcopy:
Yes, there is a button next to the surface pop-up that disables this override. When that button is pressed, the surface override pop up will become inactive and the object will use the parametric surfaces.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
4 REPLIES 4
David Maudlin
emailcopy:
Check the Model pane in the dialog box to see if the Surface is being overridden.
Hello David,
the inserted object only have one model surface, but my object has two types of surface,'
and the setting of the object saving has 4 types of surface but seems not working...
Regards
David Maudlin
emailcopy:
ah excellent,
Thanks David
