lamp: Can I load new lamps of other programs?
I work with other program for calculating the light, I want to export to archicad the lis of lams, is is possible?
1 REPLY 1
ArchiCAD can only work with its own (limited ability) lamp objects.
What do you mean by 'export the list of lamps"? You can export their coordinates and use those to align ArchiCAD lamps in the same positions. But, no illumination within ArchiCAD is based upon any reaslitic lighting model, so it is for illustration purposes only.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
