location awareness redux
David Collins
I'm trying to create some GDL objects that use location awareness to point to different subroutines of varying complexity. The script below comes direct from the GDL Cookbook, but I'm not having any luck with it. My SmartObjects are still really dumb.
Question #1: is the script correct the way I have it?
Question #2: what triggers a change? Ctlr+Shft+R doesn't seem to do it.
Question #3: "Check Script" informs me that "Use of real types can result in precision problems." That's as vague as it is disturbing. What is this trying to tell me?
!autodist is a distance parameter
!check distance from camera
!KLM are camera position, XYZ are symbol position
dkx = K~ - X~ :IF dkx=0 THEN dkx = 0.001
dly = L~ - Y~
dmz = M~ - Z~
dr = SQR(dkx^2 + dly^2) !plan distance
dd = SQR(dkx^2 + dly^2 + dmz^2) !distance including height
azi = ATN (dly/dkx) !azimuth
IF dr > autodist THEN
GOSUB 100
ENDIF
IF dr < autodist THEN
GOSUB 200
ENDIF
Thanks
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
4 REPLIES 4
David Collins
David wrote:
Question #1: is the script correct the way I have it? Question #2: what triggers a change? Ctlr+Shft+R doesn't seem to do it.
To answer my own questions, the script is fine as is. Shift+Ctrl+Alt+R is needed to force a complete update and rebuild of the model, which just Ctlr+Shft+R doesn't quite manage. Next I'm going to check and see what happens with Caplock+Macro+Shift+Ctrl+Alt+R.
I'm still curious about the error message, if someone cares to enlighten me.
David Collins
David, about the error message, try this
EPS = 0.0001 ! master script
In your current script replace
if dkx = 0 then ...
by
if abs(dkx) < EPS then ...
Refer to this link for more informations
http://download.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/LibDevGu...
For previous questions, sorry, i don't know.
David Collins
Thanks Olivier, I see what's happening now. Thanks also for the link to the GDL technical standards document. Lots of good information there.
David Collins
Yes, as you said, a lot of good stuff there.
Everyone interested with AC, not only GDL, should read it.
Here is the global link
http://download.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/BasicLib...
