‎2005-04-21 02:37 PM
‎2005-04-21 05:29 PM
David wrote:To answer my own questions, the script is fine as is. Shift+Ctrl+Alt+R is needed to force a complete update and rebuild of the model, which just Ctlr+Shft+R doesn't quite manage. Next I'm going to check and see what happens with Caplock+Macro+Shift+Ctrl+Alt+R.
Question #1: is the script correct the way I have it? Question #2: what triggers a change? Ctlr+Shft+R doesn't seem to do it.
‎2005-04-21 07:36 PM
David wrote:David, about the error message, try this
I'm still curious about the error message, if someone cares to enlighten me.
‎2005-04-22 08:02 AM
‎2005-04-22 12:03 PM
David wrote:Yes, as you said, a lot of good stuff there.
Thanks Olivier, I see what's happening now. Thanks also for the link to the GDL technical standards document. Lots of good information there.
