ELEVATE
missing library parts. but object is in Archicad28 Library
So i recently converted my AC27 template into AC28. Now I have a Missing Library Part (i.e. sliding doors). But these doors are located in the ArchiCAD 28 Library. But still shows as missing.  What Am I missing here?
Operating system used: Windows 23H2
DMD
11 Replies 11
Kebbre
@Barry Kelly - I may have a linked issue that you can assist with.
I completely understand the monolith / global library changes and I tried to use the Favorite Converter tool (https://www.graphisoft.com/resources-and-support/downloads?section=favorite-converter) to move favorites from our Monolith template to a Global Lib template.
Whilst it works for 'objects' and most elements, it doesn't convert Doors and Windows fully and keeps them as the 'Markers' and 'Stamps' are still calling for 27 library parts from the Monolith library.  (see screenshots below).
Is this expected behaviour? I would have assumed that the favorite converter would have also converted the stamp/marker call-out from the Door 27 library part but somehow it doesnt seem to have done it.
Let me know your thoughts / if it worked on your side.
Change and Innovation Lead , AC27 / macOS
I really can't help you on this one.
I don't use the default library nor the door and window markers, so I don't have any favourites set up that need converting.
If I get a chance, I will try converting a default 27 template to 28 and see what happens, but that might not be until the weekend.
Sorry.
