one object
For Doing a twisted cube Mr,Ralph explained for me!!!
But what about if we want to do some thing like what is in the attached picture!!I would like to do one of the walls starting from zero and has a special angle!!!
5 Replies 5
Ralph Wessel
Use the Regular Profile object from OBJECTiVE. Set the 'Rise' parameter to the required height, and then use the OBJECTiVE Bend tool to shape it to the required curve. You may also need to set the twisting angles depending on the specific shape you're after.
Ralph Wessel BArch
Central Innovation
Thank u For ur reply!!!
But how can i create that part u did as one part of my twisted cube!!!
as if it is one wall.and the other walls complete to be as a twisted cube!!Exactly as what is shown in my sketch model!!!igonoring the bending!!!
And Can we make any opening in the twisted cube we got!!!
noticing that the twisted cube is begining from a height !!!and that part which begins from zero continue to go up to be one of walls of the twisted cube!!
Ralph Wessel
sumayyeh wrote:
But how can i create that part u did as one part of my twisted cube!!! as if it is one wall.and the other walls complete to be as a twisted cube!!Exactly as what is shown in my sketch model!!!igonoring the bending!!
I don't understand what you're trying to do - some sketches might be in order.
Ralph Wessel BArch
Central Innovation
I Wish that my sketch will be clear enough to show what i am really trying to do!!!
I apologize If my question is not clear yet!!
Thank u..
