planview door in curtain wall
I have some trouble with door elements in curtain walls...
In 3D everything shows up fine but when looking in plan mode the elements are sometimes drawn shrunken to half the width and they look out of proportion. is this a bug or is there something I might have done wrong?
thanks in advance!
4 Replies 4
I can't be absolutely sure but it looks like a bug in the CW door script. Do you have another double door type in your library you can try to test this?
the problem magically disappeared...
I have had it with a sliding door also. its back to normal anyway.
thanks for the reply!
I'll be damned.
The doors are back to weird again. With other cw doors I can solve it by changing the the scale setting from following schaal to 1:100 or something. It worked with the double doors as well in the beginning. Now it doesn't anymore...
I hope someone from Graphisoft is reading this...
It has to be a bug.
I have the same problem. I think it's a bug! can this be fixed please.... it is very enoying. to fix is you have to go edit the cw in 3d...select the door panel...go into the panned settings...look at the general settings tab...close it and done....but to do this about 83 times in a big building does not make sence! since we are on this topic. editing muliple cw at once would be cool.
