"A serious error occured during download"
When I search for a library part and download and embed it, I very often get the
"A serious error occured during download" error.
Am I doing something wrong? What's the deal with this error?
12 REPLIES 12
vistasp
Hi MaxamAC. Are you referring to the built-in search for objects that downloads from BIMcomponents? Could a firewall be blocking access?
Knowing your OS and ARCHICAD version helps us give better answers so you might like to add that info to your signature.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Yes, object downloads from Bim Components. It doesn't seem to happen all the time... maybe just on some objects?
Archicad 19 on Max OS Yosemite 10.10.5
I'm connected to the net tru a typical home cable connection, no corporate network or such thing.
Thanks!
vistasp
Can't think of what it could be apart from a file corruption during download. If you try the same object again does it work?
= v i s t a s p =
bT Square Peg
Hmooslechner
got the same message..
Similar occures at 3.15 in this tutorial-Video :
https://www.youtube.com/watch?v=mpDofUFCmHo
vistasp
Apparently, this is a known issue that will be fixed soon.
http://archicad-talk.graphisoft.com/viewtopic.php?p=246056
= v i s t a s p =
bT Square Peg
Katalin Borszeki
Hi, ARCHICAD used to send a "Serious Error" message when downloading from BIMcomponents.com, however this bug has already been fixed and is in the 4011 update. Tx, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
Hi MaxamAC,
What version of ARCHICAD are you running? ARCHICAD 19? Have you tried updating to Hotfix 4011? Try download Hotfix 4011 from, http://www.graphisoft.com/downloads/archicad/updates/
You could visit, https://bimcomponants.com, locate your library parts and download them from here as an alternative.
I get this area A LOT. I am on a Mac.
El Capitan v10.11.6.
2x2.26 GHz Quad-Core
32 GB
ATI Radeon HD 4870 512 MB
ArchiCAD Version 19, Build 7014
FIOS Internet
I recently experience this error a lot... is it back or is this update not part of AC 20?
