"Cant find picture file: ..."
Hello everyone!
I downloaded some *.gsm objects, and when i try to insert them, i get warning message
"Can't find picture file: ......, called at line .... in the 3D script of file...."
Pictures do exist on disk (i downloaded Garden_Works_Library from this forum). I tried to put them in the same folder as gsm, but that didn't help.
I'm ArchiCAD novice, how to get those objects to work properly?
Thanks in advance!!
10 REPLIES 10
Hi Trooper,
As you said you are only using AC to convert gsm/GDL objects to aof...
So if the aof/Artlantis object is not rendering properly you should try to edit the shader/texture definitions in Artlantis.
If I well remember there is an option for select the "transparent" color in a map/texture...
But as I said you'll find better information in the Artlantis manuals and forum.
I hope it helps.
