aryastark
"Do Not Modify" Library Thing. What is that? Should i Delete?
Valar Morghulis.
In my library there is something with the end of ("Do Not Modify").
Is that a part of the Archicad's Library saying to me don't delete this? Is it important? Can i delete it?
Thanks.
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
1 Solution
Only you can decide that.
If it is not important to you then probably yes.
But you may want to save a copy of the objects (sect and export), so you have it if you need it.
You can see in the image that there are no placed objects, so if you do delete it there will be nothing missing from your model.
The "Do Not Modify" is a warning to say that they are a group of objects that all work together, so need to be kept together as is.
It will be something that was downloaded from BIMComponents.
Go to post
1 Reply 1
