"LOFT" in GDL
Hi!
If I had a start frame and an endframe that are a few meters behind and scaled and moved a bit to the right, how do I do a "LOFT" between this? I've looked at TUBE but don't think it could do it?
5 REPLIES 5
Dwight
sketch = 1000 words.
Dwight Atkinson
A sketch will help us help you!
I don't want to model 27 pieces that have same standard but with few adjustments. I'm using RULED, works ok...
David Maudlin
Tobias:
Without a picture it is hard to say, but based on your 1st post, you might also look at the Sweep command.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
Tobias:
David
I'm don't think Sweep would work, now I count my coordinates manually and build my faces with Coons and polygons (freemodeling with GDL )
www.ullna.nu <- the indoor skislope is what I modeling right now. With more detail than that easy model done in 3d Max. Maybe it's hard to see, but I don't have any 90degree anywhere and none parallells in any section of that building. But NOW I'm almost there, don't have rounded corners yet.
