radius top doors?
hi there. hopefully someone can help me. i am trying to create openings in a wall with a certain radius. i used the empty window opening with radius top from archicad se library 9. however, i can't seem to specify the radius of the curve. it only allows me to do a quarter circle. i've included a screen shot of what i've been able to model. the pink radius line is the radius i need. any ideas? thanks.
3 Replies 3
Djordje
Yep. Make your own.
For the outline, use a slab, whose ID has to be WALLHOLE.
Do a search, the procedurehas been explained many times, in minute detail.
Also, check Tips&Tricks and References forums.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
djordje,
ok, that seemed relatively easy. got it. thanks.
Djordje
marta wrote:
djordje,
Great
Djordje
HP Omen
