roof accessory help
Aussie John
Are there any links that can describe how to set the corners/or edges of a roof polygon.
I wanted to make a simple accessory to place a white fill along the non eave edges of the roof to mimic a flashing.
I think I have basically worked out the array to define the pivot lines but what about the corners of the polygon?
Cheers John
[/size]
1 REPLY 1
