rotating a picture object to appear flat in 3D?
i'm trying to rotate "picture 10" which i found in :
archicad library 10/object library/1. basic library/1.1 furnishing 10/decoration/
need to rotate it so instead of being vertical, it would appear flat in 3d mode.
or any other way of having a flat image in 3d mode would be helpful (i tried inserting as a figure but couldnt work it out, tried saving out the .jpg as an object and re-inserting but that didnt work, and the google earth addon i didnt try due to bad reviews)
sorted it! i used the carpet from the same folder in the object library with a custom picture resized.
