scale object
object settings window
signs folder
scale 10
this object only seems to allow 1m increments, which is ok for plans with scales of 1:100 but not okay for smaller or larger scales (1:5 or 1:1250 etc.)
is there a setting I’m not seeing in the parameters box which will allow for increments of 10m or 10cm etc?
v.9 (and i think earlier ones) changed the increments automatically when placed in plan
ps: my custom settings drop-down for this object is grayed-out
thanks
This ruler shows only meters, but not centimeters.
Divisions can be on 1, on 10 and on 100 meters.
For a choice of the necessary division it is necessary to stretch a ruler more than 30 meters and more than 300 meters.
thank you Valery - it worked!
regards
moji
