Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Find the perfect object, manage libraries, create custom objects
set points along a spline
I have a spline2 curve, how can I put points, or set the local coordinate system on a regular distance along the spline?
Thanks,
4 REPLIES 4
Use the Special Snap Points which can set the number of points, a percentage or a set distance.
Gerald Hoffman
ā€œThe simplification of anything is always sensationalā€ GKC
Archicad 4.55 - 29-Latest USA
yes, but I mean how placing points with a regular distance along a spline curve (or along an arc, or a polygon ...) but using GDL language. Thanks.
Pertti Paasky
Try These: http://www.tinaja.com/cubic01.asp
All You need is to study geometrics and GDL programming.
- AC-24 FIN - WIN 10 - HP Zbook -
ā€œA winner is just a loser who tried one more time.ā€
George M. Moore, Jr.
Thank you very much Mr. PƤƤsky. Be of great help to me. It's just what I was looking for!
