RandyC
stretch in increments
Is it possible to have an object stretch (snapping to ) by an increment of
say 8" ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
7 Replies 7
RandyC
To clarify , I would like the Hotspots to snap to increments as the object is stretched.
Oleg
say 8" ?
May be this solution
Parameter script:
cellSize=8"
VALUES "A" RANGE [cellSize, ] STEP cellSize, cellSize
VALUES "B" RANGE [cellSize, ] STEP cellSize, cellSize
The RANGE function definitely works. I have used it myself and it is VERY cool. I don't remember the exact syntax, but if anyone has more questions I'll look into it.
RandyC
THANKS , OLEG & MATTHEW the range function did the trick !
Randy Clarkston
WestCoast Design
Apologies if this is obvious,
You can also code explicit values for A, B, & ZZYZX for things (equipment, furniture?) that only come in certain sizes, aren't indefinitely extensive, and/or don't change size on a consistent interval. E.g.,
!bed widths
VALUES 'A' 39", !twin
			54", !Full
			60", !Queen
			76" !King
You can also bind values in different lists together using GLOB_MODPAR_NAME.
!water heater dimensions
!gallon size
VALUES 'galq'	30,		50,		75,		100,	120
!diameter
VALUES 'A' 	22", 	24", 	26", 	28", 	30"
!height
VALUES 'ZZYZX' 48",	60",			74",	76"
IF GLOB_MODPAR_NAME='galq' THEN
	IF galq=30 THEN
		PARAMETERS A=22"
		PARAMETERS ZZYZX=48"
	ENDIF
	IF galq=50 THEN....
IF GLOB_MODPAR_NAME='A' THEN
	IF A=22" THEN
		PARAMETERS galq=30
	ENDIF
	IF A=24" THEN...
So the user can choose the size from the list or stretch the diameter and the related parameters update.
James Murray
Is it possible to combine the GLOB_MODPAR_NAME with a VALUES statement in the IF THEN test ?
Conditional VALUES lists are OK in general, in my experience. I put all lists in the Master Script, it's more consistent than the Parameter Script.
Do you mean,
IF GLOB_MODPAR_NAME='name1' THEN VALUES 'A' 1',2',3'
IF GLOB_MODPAR_NAME='name2' THEN VALUES 'A' 4',5',6'
It seems to work; I've never done it in practice. There can't be a VALUES statement for the parameter that's NOT part of a conditional. IE, don't do this:
VALUES 'A' 7',8',9'
Then there's two lists for the same parameter, which, not surprisingly, gives unpredictable results.
One more thing: Parameter updating seems to get unreliable when stretching vertically in 3D. This works fine in the settings box:
IF GLOB_MODPAR_NAME='ZZYZX' THEN
	IF ZZYZX=1' THEN PARAMETERS modelname='Short'
	IF ZZYZX=3' THEN PARAMETERS modelname='Tall'
ENDIF
...but can't relied on in 3D.
James Murray
