wall extending over two stories
I have a wall extending over two stories. I need to place doors on the lower story and have them not show on the upper storey! I can’t figure if this could be done.
This is a very basic question but I’ve never really needed to do it before and always assumed that it works.
I have the lower wall set to show on all relevant stories and the doors set as symbolic cut.
2 Replies 2
Dennis Lee
I think the doors should be set to projected, and coordinate your plan view's cutting plane height to cut through the doors you want to show.
Symbolic will show no matter where the door / window is in relation to the cutting plane.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
David Maudlin
Sami:
You should change the Wall to Floor Plan Display > Cut Only, and change the Floor Plan Cut Plane Settings associated with each View. If you change the Door from Symbolic, the door will become a 3D cut of its model, not the 2D symbol you probably want.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
