Tom Krowka
window casings
Hey, what happened to the outside window casing, left and right side, on fixed and casement windows. Not showing up in the dialogue boxes. Some have left side choice only, however. Bug here, or what? I have most current library in V 12.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
3 Replies 3
Hi Tom,
Everything seems ok here (INT Library). Have you checked the ganging options? (under the "General Settings" tab) Maybe you have accidentally enabled left or right ganging.
Hope that helps,
Adrian Tudoreanu
Erich
Or perhaps you mean this? The default window settings are a bit messed up as of the last library update but fixable either by opening up the .LCF and fixing it or just changing the parameters. GS is having a few quality control issues with the library...
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Tom Krowka
In the typical fixed window, not ganged, one of the parameters for the width of the exterior casing on the window side is missing. I guess it is assumed the left and right will be the same, only the top and bottom ext. casings can vary?
[email protected]
www.walshkrowka.com
