windows missing fills
Im missing fills at various lines in the 3d script of the Casements'.gsm file for all of my windows. Its always been a problem which is frankly driving me crazy because the more windows i have in the scene the more "Fills not found" [Stop] [Continue] messages i get.
Ive no choice to click approx 4 errors per window used until i can see the model which then appears to look and export fine. How do i resolve this problem.
Im using the default AC11. library parts in AC11. All windows error in elevation, 3d windows and the library manager when adjusting the parameters.
Any help will be appreciated to save me clicking 80 times everytime i need to change my view
Regards
Bryan Richards
Look here....
http://archicad-talk.graphisoft.com/viewtopic.php?p=112747&highlight=fill#112747
Doug
Thanks, that did the trick, i had not noticed the fills were missing from this superseded template.
