Error about HTTP/2 when borrowing a license on macOS
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Affected versions: Archicad 22, 23, 24 | Severity: fixed in an update | ID: DEF-4814
Issue
On macOS, when you borrow a license from the license server, you may encounter this error:
Cause
The License Borrowing function cannot accept the HTTP/2 response, therefore the process gives an error about the HTTP/2 request.
Workaround
Currently, the Offline Borrowing function can be used to borrow a license on macOS devices The issue has been fixed in Update 4 for Archicad 24.
