beginner placing windows in complex walls
I´m working on a not vertical complex profile which section decreases with height, and when I try to place a window at the bottom of the wall, it stays far away from it. What can I do. Here a picture of the problem
3 Replies 3
Link
Check out the Opening Reference in the Complex Profile and the Opening Plane in the window tool, in your Reference Guide. The two are directly related.
Link.
thanks a lot
ok done thank you
