missing library parts from AC 10 to AC 11
Hi all,
I have been opening some older drawings to work on, and I'm finding that certain library parts aren't updating..
For instance, a drawing that was created in AC 10 is using a standard lib door called D1 10, Now in AC 11 the identical part is called D1 11??
So all that is displayed is a large grey dot. This is happening with any part that references itself to AC 10 for instance credenza 10.
Do I have to manually go round and change & update these lib parts one by one or is there an easier way???
Thx all
Have a great day
Thomas Holm
there is an "ArchiCAD Library 10 Subset" that's supposed to contain those library parts that are missing from 10 in the default ArchiCAD Library 11.
Download it from the Help>Goodies menu, install, and reload the libraries within you Library Manager. If you don't have any non standard library parts, this should take care of it.
OK
Thanks Thomas
