2026-09-16 10:54 AM
I’m currently working with Library Part Maker in Archicad 29. The workflow seems to work normally up until I use the Check function.
If there are issues with the design, the Check function identifies and displays them as expected. However, when I know the design is set up correctly and there are no apparent issues, clicking Check causes Archicad to crash and the Bug Reporter opens.
This has happened several times, so I’m wondering if this is a known issue or if anyone else has experienced the same problem.
If so, have you found a workaround or identified what might be causing it?
Thanks!
2026-09-16 05:17 PM
Are you using Monolith Library or Global Library?
And do you have the "Library Part Maker.libpack" loaded in the library manager?
2026-09-18 12:16 PM
Hi Jan,
I'm using the Global Library and have loaded the Library Part Maker.libpack. Since writing this post, I've also tried using Library Part Maker in Archicad 28 with the Monolith Library, and it works very well there.
