Brad Elliott
2.5 degree wall angle does not clean up properly
I have a wall that angles 2.5 degrees to follow the property line. It is the same composite on both walls. Instead of cleaning up properly the wall shoots a long piece into the adjacent wall and vice versa. This then messes up the windows in the wall and is a graphics problem in section. Is this just a bug or can I do something to clean this up?
I have attached an image.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Brad,
You might try moving the reference line (not the layers) for one of the walls to the other side.
Richard
AC26 (since AC6.0), Win10
Brad Elliott
Richard,
It only gets worse when I do that. For now I have it that way and have the walls just slightly apart so they don't actually close. Its a hack but it's all I can do at this time.
M1 Macbook Pro
