2D ArchiStair ?
Stress Co_
I like using ArchiStair,... but I have a problem getting things to present in 2D as I'd like. The issue is how to make the fill above the "stair break" transparent so as to see the walls below. Note: I want to see the dashed treads above the "stair break".
I've tried changing the fill and pen with no luck. Anyone have this dialed in?
Thanks
Marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
6 REPLIES 6
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
You should download the latest update from www.cigraph-store.com, we added this issue in the latest maintenance version.
Just a suggestion, please wait till tomorrow when I will upload the latest one (ver. 1.07).
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Stress Co_
Fabrizio:
Thanks for your reply and... for making this add-on available.
As long as I have your ear... and maybe this has already been addressed... a down arrow when viewing a stair from the upper floor would be great.
Grazie
Marc
Stress Co_
I just read one of your old posts concerning this issue.... never mind. ......BUT, can we rotate the UP DOWN text orientation?
Grazie
Marc
I too would like to say we need to be able to rotate the up/down text, reading upside down isn't what I want to make people do. Also I would like to be able to abbreviate DOWN as DN.
I have upgraded to v1.07, but since then I have been getting the follow error message whenever a elevation or 3D window is processed:
"CAN'T FIND MACRO: AStair_swiss,
called at line 144 of Archistair.gsm"
The model or section/elevation still looks right, and there is no message in 2D, anybody else having this issue?
Stress Co_
Scott:
You can abbreviate by: selecting the stair and opening "stair selection settings" ....Click the Hammer/Wrench icon to bring up the attached menu. I've been leaving the up/down text blank in order to get the Archistair arrows.... and then add my own text oriented in the correct direction.
Marc
thanks for the tip, hopefully archistair will allow us to rotate the text as necessary in future releases. Also I figured out why I was getting as error message, AC was loading the 1.07 plug in but still using the 1.01 library
