2D MODE- HOW DO I REDUCE SOMETHING BY HALF?
Gidday all,
Regarding 2d mode- I drew up a section of a shed- 1:100- I have a border/ titleblock I made up in 1:200...when I change it to 1:100, the actual border/titleblock is still at 1:200 but the drawing is not. Is there a way to minimise my titleblock by half so it is 1:100???
Andrew
__archiben
gidday to the west island . . .
sounds like you're mixing your model/documentation around there mate. try using plotmaker application for your titleblocks and archiCAD to generate your model/drawings. it's a much clearer, easy way to work when you know how . . .
if you persist, select everything that you want to 'resize', ensure that grouping is turned off and then go Edit>Resize. you can define it graphically, or enter x, y, z resize values (0.50 for each in your case)
HTH
~/archiben (just #*&*ing off . . .)
b e n _ f r o s t
Cheers Ben
Yeah I'm a bit all over the shop with ArchiCAD, still slowly teaching myself!!!
I'll have a go at what you said.
Thanks
Andrew
