2d line/polyline cannot be changed in AC 25-26 ARM - macOS Ventura 13.0
weeez
Hi folks,
Just upgraded to Ventura 13.0 I found a problem that 2d line/polyline/spline AC 25-26 ARM EDU cannot be modified from solid to others. Got 'locked' only in solid/default.
Hope this is not a macOS issue.
Any ideas to fix? Please kindly share.
Thank you
2 ACCEPTED SOLUTIONS
This is a known issue with Ventura. There is an article about the Ventura upgrade. You can use the arrow keys to select the line types once the drop down list is open. Also if you move the cursor to the left of the palette and further up the screen you will notice is starts to select the items. Using the arrow keys is easier though.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
https://community.Graphisoft.com/t5/Setup-License-articles/macOS-13-Ventura/ta-p/359447
Lee Hankins
8 REPLIES 8
Lee Hankins
Lee Hankins
weeez
Many thanks 🙏 arrow keys trick still work on linetype issue AC 26 3550 INT EDU (Apple Silicon). Hope it will fix soon.
ondra_z
Does anybody know when will this be fixed?
rm
This issue has lingered for more than 3 months.  Graphisoft, when will this issue be addressed and fixed?
Robert Mariani
MARIANI design studio, PLLC
Architecture / Architectural Photography
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
This article may help you:
https://community.graphisoft.com/t5/Graphisoft-Insights/Archicad-26-macOS-13-Ventura-compatibility-u...
AC 28 INT 3110/WIN 11
Thank you Mahmoud!  Wondering if they are going to take the fix back to AC24.  It looks like they are only going to fix it in AC25 & AC26 which would be very disappointing.
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
You are welcome rm, yes I have read that updates will be applied to only 2 versions ( the current and the previous to it).
