2020-11-25 08:17 AM
2021-01-23 11:49 AM
2021-02-05 04:30 PM
2021-02-05 10:06 PM
joanlinkan wrote:
That's right, it's the same project.
Thank you so much for your kind words about the project. I've had the opportunity to be in charge of the AC-model in this project and it's correct that this is made out of pure geometries, drawn by the architect in a sketch-file with a vision on what to achieve with certain roof geometries and then converted into the active model with all the right parameters that where communicated to the contractor. I've been tuning this model for almost 5 years one step at the time.
The design in the model is made basically from ALOT of triangles to match every single point.
I've drawn every single piece of the geometry of the stair with the stair tool and all the panels and handles with the morph tool, and to say the least, I feel like I am in total control of the morph tool. Triangles are my new best friend, you can achieve any geometry out of trinagles.
The key to a model that is as big as this one is to keep an organized view map when you've had around a total of 70 different employees that has been working in this model over the time of the project.
If you have any questions about any specific part of the house, feel free to ask I will try to answer you as good as I can.
2021-02-05 10:42 PM
2021-02-07 10:58 AM
Bricklyne wrote:I answer this in post #9.
Did you have to do much GDL coding to get any of the geometry done or to get some parametric functions into the models you built, or were you just working the "brute" way of building everything as is?
And what's your feeling about that (GDL coding, being able to use it, being able to extend the forms you build with basic tools, if you could)? Especially in a project of this size and scope.
Also, if you don't mind indulging us, did you use or have to use the ArchiCAD-Rhino/Grasshopper bridge and those parametric algorithmic tools and even if you did not, what are you feelings on going that kind of route, if you had to?
(like, for example, do you feel you could have been able to get this done faster than that 5 years with these tools at your disposal at their fullest (including GDL coding) if you had had access to them or were better versed in them?)
It seems like a perfect project built for that kind of workflow and this kind of design.
I feel like the people at Graphisoft should be asking designers an architects like you these sorts of questions to get a better sense of where to head with the development of this software in a more efficient way - but either way, the rest of us can still stand to learn a lot for our own situations.
Thanks in advance
2021-02-08 06:05 PM
2021-02-28 06:44 PM
joanlinkan wrote:Hi Mr. Joanlinkan. Congrats again on the great work. I have some questions (well, many!). here we go:
