AC 10 Bug ?
I was working on a project in 10 and all of the visual clues related to drawing an element (including placing the marquee) disappeared. Quitting ArchiCAD and starting it up again resolved the issue. Have other seen this behavior?
Thomas Holm
Weird things happen once in a while. Usually a rebuild cures it. But to get a FULL "rebuild from model" of sections I've been forced to slightly move the section line a couple of times. The menu command "rebuild from model" isn't enough.
Chazz
Thomas wrote:
Weird things happen once in a while. Usually a rebuild cures it. But to get a FULL "rebuild from model" of sections I've been forced to slightly move the section line a couple of times....
Ditto. Custom lib parts missing in section or line weights gone wacky. The only way to clean it up seems to be nudging the section. It's very disquieting especially since I've seen this on very simple models. On a large project this could be too much to deal with.
Nattering nabob of negativism
